I am using Creo Parametric - Release 3.0 (connected) Release 3.0 and DatecodeM160
Unable to convert PDF from Creo 3.0
Hello @NC_10259806
Not enough info to provide good guidance on. Asking therefore some questions to try to isolate the issue:
As additional information:
Serge
It is PDF
It is Generic issue. PDF conversion attempted from "drw" environment.
Thanks @NC_10259806 ,
How issue is faced exactly? is it an unexpected exit or an error thrown when trying to produce the PDF files?
Just attaching simple movie of what was tried with success from Creo 3.0 M170 => Did you use the same menus for the export attempt in PDF?
Serge
