PDF's are blurry.
mbarrett
3-Newcomer
PDF's are blurry.
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
When printing to pdf, lines and symbols become heavy. Drawings made prior print to pdf clearly. New drawings do not.
Hi @mbarrett ,
In which release are the old drawings created? You can test with the detail option symbol_font legacy and also the hidden config option intf2d_out_pdf_scale_line_fonts yes. Using a pen table or modifying an existing one can also work as mentioned.
Amol Lungare
kdirth
(To:mbarrett)
With out more information, it sounds like a pen table issue.  Did you lose your original pen table with the upgrade to 11.0?
Hi @mbarrett ,
Amol Lungare
