I'm using Creo 4,0, i want to use multiple configurations in assembly using simplified rep, I have gone through some article, but after adding the sets of constraints, I'm unable to call it in simplified rep, while giving "user defined" option in simp rep mode, I'm getting the below error, please assist me.
From your description, I think using flexibility may be what you want to use. Simplified reps get unwieldy when using them in assemblies and sub-assemblies. You can do a lot with flexibility, including suppressing and unsuppressing features and components, changing dimensions, and controlling constraint sets. Below are my notes for varying constraint sets with flexibility.
USING CONSTRAINT SETS FOR ALTERNATE ASSEMBLY LOCATIONS
Constrain part in first desired position.
Refer to FLEXIBITY below to add pre-determined flexibility.
FLEXIBILITY
When part or assembly is assembled into an assembly you will be prompted to use predefined flexibility.
FLEXIBILITY
Here is a simple example.
Thanks, kdirth, it works! Have a great day!
