Hi friends,
I have seen a tool called PTC Sketch and liked its functionalities but it says it works only in Win 7 OS so i need a suggestion for latest OS is there any tool or extension released from PTC which has the same capabilities.
Please find the link below for details of PTC sketch
https://www.ptc.com/en/products/cad/creo/sketch/download
Thank you in advance
an application that works in Windows 7 usually works in Windows 10. Download it, install it and you will see 🙂
Thanks a lot Martin. It works actually !!
