PTC Creo parametric Bom
RP_10384451
HI!
This is the sample BOM that i have created with repeat region and between this 2 rows and between every row in table i want to add blank row , so is this possible in auto generated BOM ?
you have to define repeat region in a two-line table. See attached video.
Martin Hanák
please explain what you need the second empty line for.
Martin Hanák
Martin
As you can see in attached image there are components and others things so, I generate the Auto BOM then I export the BOM In excel so there (In that empty line) I want to add temporary materials in excel sheet.
But in current situation I have to add empty line manually, and there are more than  300 lines so its time consuming process.
so.... for this I want to know if there any way that I can add a empty/blank line under every line in auto BOM....?
Martin Hanák
Thank you so much for the solution.
