Hello everyone,
when i click on this icon to open "PTC Learning Connector" i get this error:
I have made several attempts but without success.
Can you tell me how to solve it?
Thank you
P.S. I am using creo 8.0.0.0
Read this article - "Unable to connect to LearningConnector starting from Creo Parametric 7.0.0.0": https://www.ptc.com/en/support/article/cs346017
Thanks for your reply, the link in the program still can't make it work.
The only solution is to use the website directly.
It seems that I have answered my problem:
I set:
windows_browser_type chromium_browser
And
js_error_policy suppress_continue
Learning Connector does not support IE browser, so you need to change your creo browser to chromium one. to do this you have to change this in the configuration
About the script error pop, when browsing a page containing JavaScript errors in an embedded browser, a popup is thrown, you can either close the pop-up or suppress it in config so that it will not appear again.
