Paginating Hole Table
Dale_Rosema
I am working with Creo 4.0 M60
I am trying to paginate a hole table but am running into the issue of trying to "Set Extent". I get the error message "Could not set extent."
It looks like someone had the same issue 15 months ago with no solution:
https://community.ptc.com/t5/Detailing-MBD-MBE/Seperating-hole-table-on-to-multiple-sheets/m-p/560960
... and here Martin talks about "Set Extent" which I cannot do:
https://community.ptc.com/t5/Detailing-MBD-MBE/Repeat-Region-table-fitting-on-the-sheet/m-p/619460
The help file talks of "Set Extent" too:
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/index.html#page/detail%2Fhole_table_custom_create.html%23
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/index.html#page/detail%2FTo_Break_Report_Tables_on_the_Same_Sheet.html%23
Thanks, Dale
Dale_Rosema
(To:Dale_Rosema)
Caught a specific wording:
If I create the table with the number of rows I want, that works, but it doesn't see to allow me to change it after it was made (or I can't get back to the menu to set the number of rows).
Dale
TomU
(To:Dale_Rosema)
This article is for an older version, but might be worth trying:
https://www.ptc.com/en/support/article?n=CS37250
Dale_Rosema
(To:TomU)
It mentions that Paginate with repeat region table.
Is a "Hole Table" considered a repeat region table?
Dale_Rosema
(To:Dale_Rosema)
Dale
