Is there a parameter to show what the model units are?
For example: On a drawing I want to show the model mass so I use &PRO_MP_MASS[.2]. But I want to be able to show the units of the reported mass. I feel like there should be a parameter that is something like "&PTC_MASS_UNITS" or "&MODEL_MASS_UNITS", but I haven't been able to find anything.
See this pervious thread addressing this question. The method presented by @BrianMartin should work for you.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Pro-E-Model-unit-parameter/m-p/150925
Thanks @tbraxton. I was hoping there would be an easier way since it seems like an easy thing to grab and a good way to check material assignments. The method Brian Martin suggests will be difficult to apply to an already existing assembly.
