Hello
on one of our machines I need to alter the post so it generates different parameters in peck drilling cycle83 , I don't know where to look to add some parameters for this. Any ideas pls.im using creo 2
thanks mick
ex: drill c45 with drill D10(china)
cut_feed: 50-120 mm/p
peck_depth : 1-3 (breakchip)
clear_dist: 1-5
spindle; 500-700 (v/p)
nc post example:G83 X20. Y75. Z-39. Q2. R1. F50.
well done
Do you mean a parameter in the NC code that can be changed at run-time on the Machine? any luck with that by now?
