Parametric Molecule
ptc-1077260
Parametric Molecule
OK, I am experimenting with some fun designs and well trying to learn a good way to pattern objects/features in a 3D space instead of just patterning holes, or pattering and projecting along curved surfaces. Long story short, I am wanting to parametricly drive some "molecules" or lattic structures. Before I hack away at this, was curious if anybody has some good tips/tricks from their learning.
Thanks in advance!
James
This link is for a google search to help explain the types of shapes I want to make. I couldn't seem to paste screen shots into this thread.
Google Images Searchhttps://www.google.com/search?q=3d+model+molecule+proe&espv=2&biw=1920&bih=995&source=lnms&tbm=isch&sa=X&ei=_CNQVMfkMcXeoASAmILACQ&ved=0CAYQ_AUoAQ#tbm=isch&q=3d+model+molecule+diamond&facrc=_&imgdii=_&imgrc=SFbhYO4bSTYPGM%253A%3Bap6INHNP73h_nM%3Bhttp%253A%252F%252Fwww.edinformatics.com%252Fmath_science%252F...
Hi James,
You can select dimensions of features to increment (for example, a datum
point with X, Y and Z dimensions), then assemble or model a ball around
the first datum point and do a Reference pattern (so you end up with a
ball at each datum point), then add spoke off the first ball and pattern
again (just be careful what you dimension to when creating the ball or
spokes - only reference the first datum point or a reference that stays
constant throughout the pattern). If you want to go more random you can
use a pattern table to drive the 3 dimensions of your datum points. This
way you can use Excel to create the datum points (the centres of the
balls) wherever you want as a table.
I've only done this many years ago on an old version of ProE so don't know
the exact current terminology. If you run into problems I can give you a
bit more detail.
cheers
Mark von Huben
Principal Mechanical Engineer
Cochlear Ltd
1 University Ave
Macquarie Park, NSW, 2113
Australia
p +61 2 9425 5210
Hi Mark,
That was my first approach, but wow I need a machine upgrade to process that pattern. So than I thought to make my parameter driven knuckle and then pattern on a 2D plane and then pattern again to go across. No such luck, ProE doesn't allow double patterning of grouped items. I think I will go back to the totally driven 3D pattern with Excel table. That should be more flexible later on.
[cid:image001.png@01CFF2D4.F4F94880]
Hi James,
If you're running into computer processing power limitations you might try using surface features instead of solids. In my experience large patterns of surfaces regenerate much faster than solids.
Mike Foster
ATK
mlocascio
(To:ptc-1077260)
That reminds me of the tetrahedral model that I made.
