I've got a question:
Is it possible to show the value of a parameter in a Drawing as an attached note ?
Lets say that I there is a screw in a drawing of an assembly.
I want to add a note with a leader that automatically shows the value of the parameter "&designation" of the selected part.
And is it possible to add a button ("Designation-Note") to the drawing-menue ? Or is it possible to create a mapkey with that functionality ?
How can it be done ?
Thanks a lot,
Maik
according to https://support.ptc.com/appserver/cs/view/solution.jsp?source=Sitecore Article Viewer&art_lang=en&n=CS133915 you can use following notation:
&<param_name>:att_mdl
Mapkey creation is your turn ...
Thanks Martin,
It works perfectly.
