I want to hide a part of an assembly in one of the detail view of the drawing but the parent view must have that part to be shown.
Can anyone help me on this.
instead of Detailed view, create General & Partial view.
You are in the wrong forum.
PTC has two CAD systems: Creo+ and Creo Parametric and Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
To move your post, click on the three vertical dots on your initial post and click on "Notify Moderator".
Detail views are a magnification of of the original view exactly. There is very little in the way of manipulation you can do to alter the view.
As Martin said, changing the detail view to a general view is what I do to accomplish this task.
Hello @NM_12937131,
It looks like you have some responses from our community champions. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
