I'm creating a reference pattern of holes from a pattern of sketches. The reference pattern works fine. But when I go to exclude some instances of the pattern, the dots show up all right on top of each other and I can't distinguish between them or select any of them other than the first. They are all exactly in the same place, and no amount of zooming in shows any distance between them. Is there another way to exclude certain instances other than selecting the dots?
Creo Parametric 6.0.4.0
What kind of geometry is in the sketch? I'm not sure why the sketch would be patterned.
Maybe try this method? This is what I teach:
Create a sketch with points (geometry points)
Create an axis and place it on one of the sketch points (typically the lowest numbered point)
Pattern the axis to your points (different option that ref pattern... scroll down the menu)
Place your first hole on the leading axis
Create a reference pattern of holes based on the axis pattern
Placing and patterning holes to axis features seems to behave a little better in Creo in my experience.
Follow on:
I've seen the issue you're describing before. I also click on the dots to exclude features from patterns but I typically do it to the axis in axis pattern. It seems like some patterns don't like to behave occasionally and all the instances of the pattern end up overlapping in one spot. I can't think of a time where the process I previously laid out has led me to this issue. For me the axis pattern is the way to go.
