Pattern along curve and include linear dimension
ShaneV
I'm trying to create a pattern of slots where the center of the radius of the slot follows a curve but the spacing is driven by a linear dimension. Using Creo 10. Tried using pattern along a curve but the spacing distance is along the curve not linear. Unchecking the "Follow Curve Direction" allows the slots to remain parallel. Any suggestions?
Thank you,
Shane
pausob
(To:ShaneV)
Define your slot so that its centre is to follow a curve, and its centre-line location is controlled by a linear dimension:
Then use the dimension pattern to vary this dimension and generate the instances;
3 REPLIES 3
tbraxton
(To:ShaneV)
This is one way to do it. I modified an existing test model so there are some extra features. The linear dimension is defined in the point pattern; the slots are reference patterned. Creo 9 model enclosed for reference.
Involute Development, LLC
Consulting Engineers
pausob
(To:ShaneV)
ShaneV
(To:ShaneV)
Thank you both, @tbraxton  and @pausob, for your solutions.
