Pattern slot hole
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Pattern slot hole
Hi All
i have a weird behavior within a pattern.
i created a sketch with points in each corner.
on the top left, i created a slot hole with the direction as shown in picture. then i use the pattern command to pattern on the points of the sketch.
the bottom right slot hole changes the direction. why does this happen?
- Labels:
Sheet Metal Design
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Under the Options tab, unselect Follow curve direction.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Are your points relative to the side of the slot.
It looks like the bottom right slot is rotated also.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi
no, the rest is ok (slot hole horizontal) only the right bottom one is rotated by 90°
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Are you patterning 1 point 8X or 2 points 4X?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
i am pattering 1x slot hole and 2 normal holes (in the same sketch) 4 times using the points defined in the sketch created earlier.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
So is the question about the bottom right two holes or the slot or both?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
both, slot hole and 2 holes are turned by 90°
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Are you patterning by direction, dimension or something else?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
i patterned by point
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
thanks!
