Pattern slot hole
chshasa1
Pattern slot hole
Hi All
i have a weird behavior within a pattern.
i created a sketch with points in each corner.
on the top left, i created a slot hole with the direction as shown in picture. then i use the pattern command to pattern on the points of the sketch.
the bottom right slot hole changes the direction. why does this happen?
Feel the magic
kdirth
(To:chshasa1)
Under the Options tab, unselect Follow curve direction.
10 REPLIES 10
Dale_Rosema
(To:chshasa1)
Are your points relative to the side of the slot.
It looks like the bottom right slot is rotated also.
Hi
no, the rest is ok (slot hole horizontal) only the right bottom one is rotated by 90°
Feel the magic
Dale_Rosema
(To:chshasa1)
Are you patterning 1 point 8X or 2 points 4X?
i am pattering 1x slot hole and 2 normal holes (in the same sketch) 4 times using the points defined in the sketch created earlier.
Feel the magic
Dale_Rosema
(To:chshasa1)
So is the question about the bottom right two holes or the slot or both?
both, slot hole and 2 holes are turned by 90°
Feel the magic
Dale_Rosema
(To:chshasa1)
Are you patterning by direction, dimension or something else?
i patterned by point
Feel the magic
kdirth
(To:chshasa1)
chshasa1
(To:kdirth)
thanks!
Feel the magic
