Pen Table Syntax Error?
lkerila
2-Explorer
Hello all you Pro/E gurus,
I'm working on creating a pen table file to "enhance" the way my PDF files
look. Pro/E reports that I've got a syntax error on line 17. I can only
assume that means the line with pen 7. Can you help me to debug this
error? Likewise, if you have any suggestions as to how to improve the look
of my PDF files, by all means, please share with me!
Thanks in advance,
-Lar
Here is my *.pnt file...
!Chromium Design pen table as of 1-16-08 by Lar Kerila
!tweaked for use with Pro/E's PDF output function
!pen #'s map to the HP colors
!xxxx_color refers to the Pro/E entity
!colors refer to the Pro/E system color defaults
!pen #'s overrule color settings
!pen 1 thickness .025 cm; color 0, 0, 0; geometry_color
!pen 1 thickness .025 cm; color 0, 0, 0; drawing_color
pen 3 thickness .050 cm; color 0, 0, 0, curves_color
pen 4 thickness .005 cm; color 0, 0, 0; highlite_color
pen 5 thickness .010 cm; color 0, 0, 0; edge_highlite_color
pen 6 thickness .005 cm; color 0, 0, 0; letter_color
pen 7 thickness .010 cm; color 0, 0, 0; section_color
pen 8 thickness .005 cm; color 0, 0, 0; pattern 0.05, 0.05in; dtm_axis_color
0 REPLIES 0
