Pentable assigning for Drafting...
Mani_designer
Hi team,
I am converting Drafting sheet into PDF with pentable file. While exporting there's an error appears like "\Pentable.pnt : Syntax error on line 8" but the file saved as pdf. I can get the pdf file. I have separate pentable file in notepad. I don't know whether the line 8, 9& 10 can be used or not.
 Can anyone explain me the following format of Pentable is correct or any corrections to be made?
pen 1 thickness 0.04 cm; color 0.60 0.20 0.10
pen 2 thickness 0.01 cm; color 0.350 0.00 0.10
pen 3 thickness 0.015 cm; color 0.00 0.100 0.00
pen 4 thickness 0.02 cm; color 050.00 200.00 0.00
pen 5 thickness 0.03 cm; color 100.00 0.000 100.00
pen 6 thickness 0.013 cm; color 0.2 0.00 0.00
pen 7 thickness 0.013 cm; color 0.00 0.00 0.00
pen 8 thickness 0.013 cm; color 0.00 0.00 0.00
pen 9 thickness 0.013 cm; color 100.00 0.00 0.00
pen 10 thickness 0.013 cm; color 0.00 0.00 0.00
Thank You...
please read https://support.ptc.com/help/creo/creo_pma/r10.0/usascii/index.html#page/fundamentals/fundamentals/To_Change_Plotting_Pen_Attributes.html document.
!!! color values must belong to 0 to 1 interval
Martin Hanák
