Hi I want to know if this is possible. I have a workstation with 2 monitors. When I open creo it opens on the primary one. I can drag the windows to the second one but every time I open a new part it opens on the primary. Is there a way to pin the program to the second monitor? I have a scenario where I would like WF4 open on one monitor and creo on the other. Any bright ideas most appreciated! Thanks
Hmm I only see the regular icons (minimise, maximise, close). Does this mean my graphics card doesn't support it or do I need to enable an option?
Brilliant, that looks like just what I am after. Thanks 🙂
Since Creo is not a Windows app software and only interacts with Window thru xtop.exe there is two ways to accomplish this. Windows software remembers which monitor the software was on when it is closed and will open it to the same monitor.
Downside: Creo is centered in the 2nd monitor, but every new Creo window opens on 2nd monitor
C:\RTN\PTC\Creo 3.0\x64_creo3-m120\Creo 3.0\M120\Common Files\x86e_win64\obj
Downside: Each new Creo window opens on primary monitor, must use Alt + Z to move to 2nd monitor
