I would like to know if it's possible to adjust the angles of the "legs" used when you insert break points in a segment of pipe, then move that pipe segment. It seems to only use 90 degree bends even if the line stock specifies only 45 degrees as a bend angle.
Here's a basic pipe run I made this as a quick example...
Add 2 break points to the 120" segment, 24" from each end.
Use the Move Segment command to move the new segment by 12"
After completing the command double click the 12" segment (what I referred to above as the "legs") created. Notice there are no angular adjustments possible...only bend radius and the length can be adjusted.
Try not to freak out when you realize there's no way to get that 12" segment to use bend angles other than 90 degrees
Does ANYONE know of a way to add an offset to an existing pipe segment that will allow you to adjust the angle of the legs?
