Please advise on the short cut key on the modeling.
Please advise on the all the short cut key for the Creo Elements/Direct modeling.
Usually they can be found at the help of Creo Elements/Direct Modeling
But for any reason, if you dont have access to help, you can also find it at
http://www.mip-group.com/technical/Quick-Reference/Quick_reference_guide_V19.pdf
What short cut keys are you referring to? What is built in? How to modify and add your own? Which version of Creo Elements/Direct are you working in?
Tom
