The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
Does anyone know how to add the diameter symbol to the position tolerance by default?
OR....
There is a constant value of .002 that pops up as the default value for GDT - anyone know where that is store?
As far as I could find, there doesn't seem to be any configuration parameter you can set to make any of the geometric tolerance options default. It's a clunky beast that I just live with.
From the behavior I've witnessed using it, it seems that once you create a tolerance, the numeric value (0.002, 0.010, etc.) is retained from the last one you did. Sometimes it seems like the type of tolerance is also kept, but I'm not so sure about that one.
I suppose if I wanted to not have to click and enter all the settings I want for a bunch of tolerances, I could create one or a set of mapkeys to "preload" the geometric tolerance definition(s) I want to create.
