Security Alert Log4j Security Vulnerability. Click here to know more.
Posted a question to PTC three weeks ago, no answer so far...
FV
Hi all,
About three weeks ago I had logged a technical call to PTC (C5774753). The question was rather simple – in a drawing mode while creating a symbol instance or a note for example in order to attach the parametric leader to a midpoint of the selected edge you have to set ProSelectionUvParamSet to a UV parameter of the edge. The UV parameter of the edge could be obtained with ProEdgeUvdataEval. The problem is that the function returns a two member array of the UV parameters for the adjacent surfaces. So my question was which array member I should choose. PTC still did not give me any answers.
Here is a code snippet:
ProGeomitem edge_gi;
ProEdge edge;
ProUvParam uv_point[2], uv_deriv1, uv_deriv2;
ProVector xyz_point, xyz_deriv1, xyz_deriv2, direction;
ProView drw_view;
ProAsmcomppath cpath;
err = ProGeomitemToEdge( &edge_gi, &edge);
err = ProEdgeUvdataEval( edge, 0.5, uv_point, uv_deriv1, uv_deriv2);
err = ProEdgeXyzdataEval( edge, 0.5, xyz_point, xyz_deriv1, xyz_deriv2, direction);
err = ProSelectionAlloc( &cpath, &edge_gi, &sel);
err = ProSelectionViewSet( drw_view, &sel);
err = ProSelectionPoint3dSet( xyz_point, &sel);
err = ProSelectionUvParamSet( sel, uv_point[0]);
//or
err = ProSelectionUvParamSet( sel, uv_point[1]);
Although I had found a solution I want to run an experiment. How long would it require for a group to find a correct answer. How it compares to a promptness and technical quality of PTC provided answer if PTC would eventually respond.
I will postmy workaround for UV paramin a couple of days.
Thanks.
Feliks.
FV
(To:FV)
Hi all,
Thanks everybody who emailed me an answer.
The answer is: set U parameter to be equal to theedge parameter t and V parameter to be equal zero.
PTC help center had finally responded and pointed out that the answer could be found in "Unpacking a ProSelection Object" section of the User Guide.
Feliks.
FV
(To:FV)
Hi all,
Feliks.
