Pro Diagram Question
abesau1
1-Newbie
Not sure if this is the right forum, but hopefully someone here knows the answer.
In Pro Diagram, is there a way to reset the wire count?
When you delete wires and start adding them again, it does not rest itself.
Lets say you routed wire1, wire2, wire4 and wire5, then you delete wire5.
Then you start routing again, the count resumes at wire6 not with wire5.
Hopefully this makes sense.
1 REPLY 1
Hi Abel,
I consulted the Pro/Diagram master Ed Przywara.
He said:
Sorry can't fix that. Just know that it's an issue and correct it when
you complete with the entire diagram by modifying the value for the
parameter.
Ed
So let it be written, so let it be done...
Frederick Burke
Avionics Installations Engineer
Fire Scout VTUAV - Unmanned Systems
Northrop Grumman Corporation
858-618-7163
858-618-7186 (FAX)
