Hey All,
I will be taking delivery of a new Dell Precision M7710 Workstation today. I have to log onto my account on www.ptc.com and obtain my new license file.
After I obtain the new license file, how do I install Wildfire 5.0 and Creo 2.0. I no longer have maintenance and I have had issues every time I have ever tried to install Pro|E. Can anybody point me to a comprehensive installation guide online? The only components that I need are my Foundation XE package with the Mechanism Design Extension as well as Mechanica Lite. I don't use Windchill, etc.
If anybody out there can assist me either in person or remotely, then this is also an option and I would be happy to discuss cost offline. I asked PTC if I could pay them for a consultation. They said that they will ONLY help me if I restart my maintenance.
My license is a Floating License (I scrolled down the license file and this is what it says). It is permanent license (Expiration Date: permanent):
#################### FLOATING License ####################
# Serviceable = Pro/ENGINEER Foundation XE (formerly Foundation Advantage Package)
# Feature Name = PROE_FoundationAdvM
# Feature Version = 31.0
# Number of Copies = 1
# Expiration Date = permanent
I have Google searched for an installation guide and all that have found are installation guides for the cracks and hacks.
TIA and Happy Holidays,
--Neal Rosenblum 954-649-9399
according to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS154266 Feature Version = 31.0 enables you to run ProE WF5, not Creo 2.0.
Creo 2.0 needs Feature Version = 33.0.
MH
Try following links
http://support.ptc.com/WCMS/files/123932/en/WF5_M080_install.pdf
Creo 2.0 installation is similar to Creo 3.0.
Suggestion:
MH
Dear Martin,
At the time I ended maintenance, Creo 2.0 was already out and I just had not installed it yet. So I made the cutoff for licensing.
Thank you,
--Neal
ask PTC to send you Customer Detailed Report - it contains list of your licenses including their maintenance end date. I hope PTC will send you Creo 2.0 license, if CDR tells you that you have rights to get it.
MH
Dear Martin,
Also thank you for the PDF link for WF50.
--Neal
