Jnanesha
Yes you can convert / save a multiple sheet ProE drawing to a multiple sheet AutoCad drawing ".DWG". While doing the save as process select the sheets tab and select the "All sheets as paper space" option.
Dave McClinton
MCAD System Administrator
McKesson Automation
724 741 7760
Only recent releases of Pro/E can export the entire drawing to AutoCAD..
For example, Wildfire 3 does not have this option.
Is there any way to convert pro-e drawing to AutoCAD drawings (DWG
format). I am aware of the fact that we can convert using save a copy
option but it does one sheet at a time.
Is there a method to make entire file converted to DWG?
Thanks and regards,
Jnanesha KS
T 91-80-4119 0900 Ext: 233
F 91-80-41190901
M 994 500 4179
Quality Engineering and Software Technologies
No 55 l QuEST Towers l Mahadevapura l Whitefield Main Road
Bangalore l 560048 l www.quest-global.com http://www.quest-global.com
