Jeff,
Leave the door packaged then use the assembly move commands to drag the door around the axis of the hinge. You can do collision and other interference checking while you do this.
Ronald B. Grabau
ME Applications Engineer
HP - Houston
You can also use the mechanism to save out a Envelope component that is super light weight and static and represents the motion envelope.
These are all much better methods than creating representing geometry features
