Pro Man, W5 M60
ptc-21369
Pro Man, W5 M60
I am posting a program to a machine tool that does not except moves less than .0002. Is there a way that I can control the data output without sacrificing the quality of a majority of the finishcuts? Is it possible to do this in the parameters?
Ronald Swift
Engineering Supervisor
Zirc Company
3918 Highway 55 SE.
Buffalo, MN. 55313
rons@zirc.com
P: 800-328-3899 | 763-682-6636 | F: 763-682-6604
Hi Ronald,
You can set the linear resolution in GPOST to be 0.0002” – However, that won’t guarantee your finish cuts will be as good as it could be (Or as good the Pro/NC computed it to be) as the post will skip moves that do not fall within that resolution.
Cheers
Daniel
