Pro/Piping
ptc-1731224
1-Newbie
Pro/Piping
I'm trying to create a bend in my route that is greater than 90deg. Every time I try this whether it is with cartesian coords or spherical or cylindrilical the segment fails. Is there anyone that knows how to do this that can give me some pointers? BTW, I'm using WF2. Thanks.
1 REPLY 1
CBenner
(To:ptc-1731224)
Are you using spec-driven piping? Try using the route option "Axis/Edge/segment". When you choose "Extend" in your Route menu... pick the option "Csys/Axis"... then the sub-option mentioned above. You may have to setup a datum plane first, at the angle you want for the route... then select that during the routing as an angular reference for the segment.
Chris Benner
Autodesk ® Expert Elite
