Pro/e drawings for use in tech. documents
BillChapman
I am creating images in drawing mode that will be brought into MS Word. I have set the fonts for notes/ dimensions to be Arial as this is the font to be used in Word. The Arial in Pro/e looks much different than the Arial in MS word. The pro/e Arial is much thicker. Is there a way to get these consistent? Also the height is off, I though to get Arial 10 pt the text height should be 10/72 = .139", but this comes out much larger.
The output is generic postscript that I change the file extension to EPS int import into Word. Insert -> Picture -> From File. The file looks clunky in Word, but print OK. Why does it look pixelated in Word?
Bill
0 REPLIES 0
