ProE WF3 M250 on Windows7 x64
ANTHONYHAMEN
I have installed ProE WF3 M250 on a Windows7 x64 bit laptop with an Intralink 3.4 M040 client.
When launching ProE from Intralink, it does work perfectly but when trying to launch ProE directly and independantly from Intralink, I get an error message :
"Windows cannot find <Proe Load Point>\i486_nt\nms\nmsd.exe"
It is quite normal as it a 64bit version of ProE, the nmsd.exe application is located here : <installation folder>\x86e_win64\nms\nmsd.exe
What can I do ?
2 REPLIES 2
DHLewis
(To:ANTHONYHAMEN)
Tony,
Your installation is incorrect as it is looking for the x86 version of nmsd.exe instead of the x64 version. Have you modified the launch files yourself to make this work in Windows 7 x64? Try re-installing the x64 version of Pro/E and check the option to add/modify the command files.
David
Anthony,
your installation of ProE WF3 M250 is 32-bit. Intralink is also 32-bit.
I think you have to modify psf file in PROE\bin directory and replace every occurence of %PRO_MACHINE_TYPE% with i486_nt
Example psf file before modification
// PTC - PSF file: proe
PRODUCT=Pro/ENGINEER
DESC=proeWildfire3_M240
ENV=INTRALINK_DIR=
ENV=ILINK_CMD_NAME=
ENV=INTRALINK_CMD=%INTRALINK_DIR%\bin\%ILINK_CMD_NAME%
ENV=MECH_LP=
ENV=MECH_HOME=%MECH_LP%\%PRO_MACHINE_TYPE%
PSF=%MECH_LP%\install\nt\mech.psf
ENV=PRO_MECH_COMMAND="%PRO_DIRECTORY%\bin\proe.exe" "%PRO_DIRECTORY%\bin\proeWildfire3_M240.psf"
ENV=PATH+=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\deflib
ENV=PATH-=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\lib
ENV=PATH-=%INTRALINK_DIR%\%PRO_MACHINE_TYPE%\illib
ENV=PTCNMSPORT=1239
ENV=NMSD_TIMEOUT=300
ENV=PRO_COMM_MSG_EXE=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\pro_comm_msg.exe
ENV=PROE_START=%PRO_DIRECTORY%\bin\proe.exe
ENV=CDRS_DATA=%PRO_DIRECTORY%
ENV=PRO_IMAGE_CONVERTER=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\convert_image.exe
ENV=GALAXYHOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%
ENV=PROGUIDE_DIRECTORY=%PRO_DIRECTORY%\uifdoc
ENV=SPG_DIRECTORY=%PRO_DIRECTORY%
ENV=PRO_USRMAIN=%PRO_DIRECTORY%\usrprog\umain\usrmain.c
ENV=PROTABLE_DIRECTORY=%PRO_DIRECTORY%\protable
ENV=PROTAB=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\protab.exe
ENV=ZIP_EXEC=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\zip.exe
ENV=CLHOME=%PRO_DIRECTORY%\text\pcldata
ENV=PVIEW_PVEXPORT_HOME=%PRO_DIRECTORY%\apps\prodview
ENV=PVIEW_PROEPVIEW_HOME=%PRO_DIRECTORY%\apps\prodview
ENV=CV_ENV_HOME=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\CV102
ENV=VC_VCONF_START=%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\ptcvconf.exe
ENV=PTC_D_LICENSE_FILE-=7788@licserver
ENV=PROE_FEATURE_NAME=PROE_licence_name ()
RUN="%MECH_LP%\install\nt\pro_mech_env.bat"
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\nms\nmsd.exe" -noservice -timeout %NMSD_TIMEOUT% &
RUN="%PRO_DIRECTORY%\%PRO_MACHINE_TYPE%\obj\xtop.exe"
// USER - PSF
// Add User specific environment or run applications below here
Example psf file after modification
ENV=INTRALINK_DIR=
ENV=ILINK_CMD_NAME=
ENV=MECH_LP=
ENV=MECH_HOME=%MECH_LP%\i486_nt
ENV=PATH+=%PRO_DIRECTORY%\i486_nt\deflib
ENV=PATH-=%PRO_DIRECTORY%\i486_nt\lib
ENV=PATH-=%INTRALINK_DIR%\i486_nt\illib
ENV=PTCNMSPORT=1239
ENV=PRO_COMM_MSG_EXE=%PRO_DIRECTORY%\i486_nt\obj\pro_comm_msg.exe
ENV=PRO_IMAGE_CONVERTER=%PRO_DIRECTORY%\i486_nt\obj\convert_image.exe
ENV=GALAXYHOME=%PRO_DIRECTORY%\i486_nt
ENV=PROTAB=%PRO_DIRECTORY%\i486_nt\obj\protab.exe
ENV=ZIP_EXEC=%PRO_DIRECTORY%\i486_nt\obj\zip.exe
ENV=CV_ENV_HOME=%PRO_DIRECTORY%\i486_nt\CV102
ENV=VC_VCONF_START=%PRO_DIRECTORY%\i486_nt\obj\ptcvconf.exe
RUN="%PRO_DIRECTORY%\i486_nt\nms\nmsd.exe" -noservice -timeout %NMSD_TIMEOUT% &
RUN="%PRO_DIRECTORY%\i486_nt\obj\xtop.exe"
// USER - PSF
Good luck
Martin
Martin Hanák
