ProTK: ProIntfSliceFileExport and SimpReps
OlafOelsner
1-Newbie
Hello, I try to export an external SimpRep as an STL file. The STL file should only visible components, but currently it contains all components. What do I have to do to export only visible components ? Thanks in advance Olaf Oelsner
2 REPLIES 2
Hi Olaf, perhaps it is better if you make this in two steps. At first you can create a simplified representation with all your parts you need. Click then File-> Save a Copy. The new name is for example "test". Now you must change the Type. Choose "External Simplified Representation" and then return. Open this file and create a stl part. Good Luck! Regards Jürgen
Hi Jürgen, thank you for the answer, but I have the Problem only when I try to do it with the Pro/Toolkit function ProIntfSliceFileExport. Best regards Olaf.
