Problem with AAX and ISDX
jo'neill-2
I recently had a hard drive failure. When I got my computer back from IT, I was no longer able to use AAX (Advanced Assembly Extension) and ISDX (Interactive Surface Design Extension).
My IT person insists that he installed the same license file.
Is there a separate license file for these modules? Would he have had to install these modules separately? Is there a way to tell which modules are installed / licensed? I've gone to File >> Help >> System Information, but I don't see anything that looks like AAX or ISDX.
I am using Creo 2.0.
Ok, you need to move PROE_FlexAdvISD on top priority. Select PROE_FlexAdvISD license in list and use up arrow to move that upside.
8 REPLIES 8
Possible these licenses were not not added in command to start. You may need to reconfigure Creo 2.0
1. Run reconfigure.exe from <Creo 2.0 install location>\Parametric\bin
2. Select Next > Next > Customize
3. Select Command configuration > Edit
4. Move required Licenses from left to right > Ok > Ok > Install.
Hope this will help.
Thank you for your help.
When I ran the utility, these were the licenses listed to run:
There were no additional licenses on the left-hand side.
John
Yes, that worked. Thank you very much.
John
Now that I have done this, my Flexible Modeling has disappeared. Does one prevent the other from running?
I think, reason of this is, License for Flexible modeling is a part of PROE_EssentialI and AAX & ISDX are in PROE_FlexAdvISD, so when Creo will launch for sirst time, it will use PROE_FlexAdvISD. In that session you will get AAX and ISDX, if you will launch new session, it will use PROE_EssentialI which will allow flexible modeling.
Thank you. This worked.
