Problem with Merge / Inheritance
c.strohhacker
One of my co-workers is working on a part which uses an inherited part as its base. Periodically the base will disappear and consequently all the features under it fail. What’s the problem with the Inheritance? And is there a fix?
I’ve seen this with a merge and usually it seemed to happen when the user had hidden the merge feature in the model tree, this is not the case with the inherited part.
WF3 M250
Chris.
0 REPLIES 0
