I don't use simp reps very often so please bare with me...
I have a user who has changed the default simp rep. Now when you open the assembly it opens in the default simp rep. How do I get the assembly to always open in the Master simp rep?
The master rep is the assembly that is used in drawings and other assemblies. So when it comes up in the default simp rep parts are missing and there are other problems.
I have set the simp rep to master. Saved the assembly. Then erased the assembly and when I open it, it's back to the default simp rep...
Help!!!
Mark Nerby
Fluke Corp
425 446 5271
Weavoid changing the default or standard states of items like this to avoid these types of situations. This way, when you initially open something you get what you expect and not some specifically modified version you need to change if you want the "standard."
