Problems with the "Modernized Project/Offset Tools" in Sketcher of Creo 9.0.0.0
bmancini
I have several problems with the Modernized Project/Offset Tools in Sketcher of Creo 9.0.0.0.
I wish I could go back to the old command present in creo 8.0...
I explain what the problems are:
PROBLEM 1:
In creo 9.0.0.0 the project / offset tool does not generate the arc centers of a loop.
PROBLEM 2:
After using the command I would like to be able to select specific segments and arcs generated with the Project / Offset command and then perhaps mirror them, but with the new command it is no longer possible ... all entities are selected as a group, is there a way to explode them?
PROBLEM 3:
The "Delete Segment" command is NOT ABLE to recognize the segments defined by a project / offset loop of a curve with intersections on the segments and references.
P.S. Notice the yellow dots that delimit the recognized segments.
PROBLEM 4:
I would like my arc to have the same radius value as the arc of the offset chain, but the program does not allow me to set the constraint because it sees the entities of the offset chain as "a single group entity".
I am really disappointed with the command, I think it is intolerable.
I have watched all the official videos on using the command, but still I cannot appreciate this new version of the tool.
Does anyone know if it was possible to reactivate the old command?
I'm curious how you feel with the new command.
Thank you.
31 REPLIES 31
tbraxton
22-Sapphire I
(To:bmancini)
Reverting to the "old" command  is not supported in Creo 9.
The documentation indicates the ability to switch between chain selection to one-by-one.
"Switching from rule-based definition to individually selected items is supported for “Project”-tool"
Have you tested the method presented here?
https://www.ptc.com/en/support/article/CS369555
If it does not work then you need to open a call with support. If you log a call and an SPR is generated, please post that information in this thread.
Involute Development, LLC
Consulting Engineers
bmancini
(To:tbraxton)
Thanks tbraxton for the reply,
I read the articles:
and
https://www.ptc.com/en/support/article/CS369607.
What they propose in the CS369555 to convert the chain to one-by-one for the "Project" tool may be reasonable, but I still don't like it.
What they propose in the CS369607 to convert the chain to one-by-one for the "Project / offset" tool with the "thickness" tool is unreasonable because, in my experience, the tool inevitably creates a double entity profile forcing the operator to select one by one all the entities of the second useless profile.
Can anyone tell me if it is possible to obtain only one offset profile with the "thickness" tool?
I continue to be very frustrated and disappointed.
and
I think the best way how to get the answer is contacting PTC Support.
Martin Hanák
The articles 369555 and 369607 have been updated. We hope that gives more background to the reasons and intent of the changed behavior and the recommended workflows.
R&D is continuing to research potential further refinements to the new workflow for future releases.
In addition, we currently plan to add the "All-curves-in-feature" rule to the chain collection workflow in Creo 9.0.2 which was not included in the initial implementation in Creo 9.0
bmancini
(To:mneumueller)
Thanks Mneumueller for the update.
I hope the situation improves soon.
I wish you good work.
Bumping this up and encouraging all to go and vote on the submitted product idea and voicing your opinion about this situation.  Though it is stories such as these that make me think that the "product ideas" part of this community is a bit of a waste of user's time and it has become more of an end process for PTC when resolving support cases: 1) customer points out a problem and opens a support case; 2) customer is told "software works to specification", so they are asked to file a product improvement idea; 3) case closed; customer feels better, thinking something will be done.
It's rather brilliant - PTC gets a well documented report of a deficiency (for free), the to-do list is automatically updated, and if and when they feel like it, R&D will work on it sometime.
The implementation of the "improved project/offset tools" is disappointing, (perhaps in part due to lack of end-user testing and feedback): PTC removes the user-liked functionality and arguably, does not fundamentally add anything new - because the option of constructing composite curves and using them for projecting in the sketch was already available.
Circling back to product ideas: I'm curious why R&D worked on "improving" the project / offset tools in the sketch?  The articles tout the benefits of standardized workflow, sketch stability, reduction in the number of references to manage, etc...  That's arguably all real and valid, but my point is that I don't recall one product idea in which a customer asked for this "improvement" and started the ball rolling.  But then again, I probably missed it - among countless user ideas that have been ignored by PTC... for decades.
bmancini
(To:bmancini)
Reporting other anomaly:
PROBLEM 5:
If in the sheet metal environment I try to close an opening with the "Wall" command, and then use the project to detect the profile, the feature goes into error ...
If I draw the outline without using the projection, it works!
Dear bmancnini,
thank you for your additional report #5, even though I don't think it is related to this topic/thread of modernized Project tool. as it seems this is a behavior also seen in previous versions. Actually when I quickly tried it now, I only saw it in prev versions and I couldn't reproduce it in Creo 9.0 anymore.
Therefore, I would encourage you to report a SPR to Technical Support along with the problematic Creo 9.0 example, so that R&D can have a look at it.
Meanwhile here some alternative workflows using parametric regeneration of the loop that worked for me. You can try them out:
a) Use the "Remove Feature" on the "Loop Surfaces" (by specifying the surface and an edge of the inner contour).
or
b) Use the planar wall feature referencing an external sketch containing the projected geometry
or
c) Use the planar wall feature with an internal sketch and projected entities as in your example, but check the Planar Wall feature option "Do not merge to model". Then use the separate "Merge Wall" feature to merge in a second step
best regards
I got a small update from R&D: a fix for this went into Creo 9.0.1.0
bmancini
(To:bmancini)
PROBLEM 6:
Other anomaly ...
if in a sketch, I mirror a geometry generated with the loop project, the program is not able to maintain the dimensional constraints of the parent geometry ...
Thanks - will check with R&D
Aaron_Daniel
(To:bmancini)
In the past PTC has often included an option in the config file to use a new method or retain the old method - they should have done that with this workflow change.  Not only does the new method require additional mouse activity and clicks, it's not reasonably intuitive to implement, and it eliminated previous selection capabilities.
Prior to the "Modernized Project/Offset Tool"...
When using 'Project' within Sketcher, when set to 'LOOP', a prior sketch could be selected, and all of the prior sketch's elements would be created.
This ability is gone in Creo 9.0.
One ability that I have desired of 'Project' and 'Offset' is to pick a surface, and have all the surface edges selected (holes, cuts, or protrusions).  If I have a boiler tube sheet with many holes, I might want to select all but two or three of the holes in a new sketch.  As it has always been in Creo, I have to select the edges of maybe 40 of 43 holes...rather than select all of the holes in the sheet, and then "de-select" the three that I don't need - very counter-productive.
For reference see:  Projecting Curves or Edges in Sketcher - PTC Community<https://community.ptc.com/t5/Creo-Parametric-Ideas/Projecting-Curves-or-Edges-in-Sketcher/idi-p/727309>
There should be a way to select a surface and create sketcher entities of every edge.
The new "Modernized Project/Offset Tool" could be improved by adding some enhancements as described below
A) In the Chain>References>Rule-based window –add a ‘Rule:’ button for “All Surface Loops”.
B) In the Chain>References>Rule-based window –add a ‘Rule:’ button for “Selected Sketch/s”. (This would add the capability available in previous Creo versions as described above).
C) Somewhere in the selection process there needs to be a button to select if the selection chain is treated as a complete inclusive chain, or as individual sketch entities.
D) Make it so that exiting the reference selection process automatically selects all that has been selected and creates the sketcher elements – instead of having to select a button (losing all the elements if not selected) to exit the process.
E) In the Chain>References>Rule-based window –add button to remember all the current selection options.
Again, there should have been a config option to keep the old method, or use the new method (so that those who wished to struggle through the new implementation could contribute to its refinement till it is actually beneficial).  The new method has some interesting possibilities in terms of "Intent" (so that changes to geometry prior to a sketch do no not cause unnecessary failures or unpredictable results...so it could be a good way to go...with some refinements.  Until that happens, the new method is an irritating frustrating time-trap!
it is correct that we do consider these adoption options when we do significant changes, but there are implementations where this is not feasible due to incompatibility and other reasons as in this case. To a certain extend, the currently available capability to switch to individual entities should somewhat represent a way to get close to the previous behavior (at least for project)
We did include this capability in the beta testing, but unfortunately the problematic aspects had not been raised at that time.
R&D is investigating how to refine the workflows to provide combined benefits of previous and new behaviors for the various use cases. For example - as mentioned in the article - Creo 9.0.2 includes the "all curves in feature" option, which will address some of your points.
Addition: Please see update at:   Fix Modernized Project and Offset Tools in Sketche... - PTC Community
And if you are interested in joining our review, just le me know as indiciated.
StevenB1
(To:mneumueller)
Does this hidden config option allow the user to revert to previous behavior?
SKETCHER_USE_CREO8_PROJ_OFFSET
I see now in your linked thread you have listed this option to revert to Creo 8 projection behavior.
yes, correct.
bmancini
(To:bmancini)
PROBLEM 7:
Usually with Creo 8.0 to create a counterbore slot for screw, I used the project offset command, then I deleted the relative offset dimension (Picture 1),
the program converted the "edge offset" constraints into coincidence constraints, tangency and horizontality and finally I added a dimension to the diameter of an arc of the slot, work completed (Picture 2).
Now in Creo 9.0.0.0 I am no longer able to perform these steps.
When I delete the offset value, the program converts the only offset constraint of the complete or partial loop (picture 3)
into tangent and horizontal constraints but not coincident in the centers of the arcs ... (Picture 4).
This behavior is partly attributable to other unwanted behaviors that I have already reported in other points of this discussion, but I wanted to report it anyway because, for me it is a basic use of the project offset command.
tbraxton
22-Sapphire I
(To:bmancini)
Keep posting the use cases where the new tool is not better or incapable of the same results as the previous implementation. It is the best way to get a resolution implemented. If you have not done so yet, I would open a support case for these issues. Once an SPR is assigned then it is tracked internally at PTC.
please replay video diameter_dim.mp4 related to PROBLEM 7.
Martin Hanák
bmancini
(To:MartinHanak)
Hi Martin,
thanks for the video, having preached the diameters of the buttonhole is a procedure, which although more elaborate than it was in Creo 8.0, that works! Good job!
I'm curious, have you experienced it personally or have you found it in some other discussion, I tried to look for other discussions but without success.
I just tested if problem 7 is related to sketch reference selection. And I was lucky to hit it.
Martin Hanák
Add me to the long list of users who are incredible frustrated by this de-hancement. Our company leapfrogged from Creo 8 to Creo 10, so I'm late to the party, but this change is positively horrible. We have lost some fundamental functionality in project and offset in sketcher. Losing the ability to select a surface to project or offset a loop, and losing the ability manipulate individual segments of project/offset of full or partial loops, has made the tool less useful and the workflow less efficient.
I've been a regular user of Pro/E / Creo since 1990 (Pro/Engineer Rev 5). This is the single biggest UX blunder I have experienced in any update over all those years. Please listen to your users and fix this! I'm right now trying to figure out how to get an authorization code to allow deprecated config and enable the SKETCHER_USE_CREO8_PROJ_OFFSET config option.
bmancini
(To:steveemmert)
maybe you missed it or you tried it and it doesn't work, in any case, in the last post of this article "https://community.ptc.com/t5/Creo-Parametric-Ideas/Fix-Modernized-Project-and- Offset-Tools-in-Sketcher/idc-p/834411/highlight/true" they write that If you are using a Creo with version Creo 10 with version higher than 10.0.4.0, you should not need an authorization code.
So maybe you just need to update the datecode and make sure you added the option correctly in the config.
I can use the old offset command on Creo 11 simply by adding this line in the config "SKETCHER_USE_CREO8_PROJ_OFFSET yes".
We are still on 10.0.3.0. My support guy is saying we would need to be on 10.0.4.0 or newer in order to apply this config option at all. Are you saying we can do this on 10.0.3.0 so long as we have an authorization code?
Thanks!
bmancini
(To:steveemmert)
No, I'm saying that I think it is very simple to solve the problem by updating the program to datacode 10.0.4.0 or 10.0.5.0.
But I assume that if you haven't already done so, you have some constraints in your company that I don't know about.
Same here. Our company just updated CREO to 9.0.7.0 version. Due to corporate policy we are unable to update to any higher version soon, so we have to work with 9.0.7.0 for quite a long time (a year at least). The mentioned change literally drives us to fury, because we use the projection and offset tool very often. We have many control models available (thanks to top-down based projects) in which the geometry is based on hundreds of predefined curves in predefined layers, all controlled by very complex ralations and user parameters . All derived models refer to the top level control model, and the projection of reference curves is the main method of creating new models. The mentioned changes in our work caused a literal disaster! For years we worked on improving the control models within the top-down structure, Now I will have to completely rework them, since the whole concept was based on the projection of the top model (sketch based) geometry and the subsequent manipulation of a part of the projected geometry! Some of my works is already ruined due to the fact that the projected geometry cannot be further manipulated. Other workflow is "only" several times longer, due to lack of instant "loop" option. Thank you PTC for the "excellent" update!!!
The only hope for us is to activate the mentioned configuration option SKETCHER_USE_CREO8_PROJ_OFFSET!
Is it possible to implement this option in 9.0.7.0 version?
Tooling Designer in ZF Slovakia
With 9.0.7.0 you can contact PTC Technical Support to get an allow code for the configuration option to become activated. With 9.0.8.0 and higher Creo 9 versions the allow code is no longer required.
will do, thanks for quick info
My IT guys just released an update to 10.0.5.0, with the "SKETCHER_USE_CREO8_PROJ_OFFSET yes" option added to the admin config.pro, and my life just got dramatically better! Even after just testing out the update for them for a brief time, I am awestruck by just how horrible the new interface is, and how dramatically more efficient and effective the old interface was. Thanks for providing a way to revert back. PLEASE listen to your users and make this reversion to the old interface permanent.
