Dwayne,
Someone will probably come up with a neater way of doing this, but the way I do it is I create an offset surface from the surface that needs the text/logo etc (make the offset as small as possible), I then copy that surface, trim it using the projected curve and then give it a different colour so that it shows up. This can be a bit time consuming though as you need to repeat the copy and trim steps for each 'loop' in the curve.
Simon Lewis
Control Techniques
