Publish geometry and Windchill relationships
khimani_mohiki
We want to start making use of Publish geometry and Merge / Inheritance features in Creo, but there is very little information about what type of relationships this creates in Windchill. We have had many problems in the past with extenal references causing many unwanted items to be collected when we initiate workflows.
I can see that copying published geometry into a part creates different types of references depending on whether you have update control set to 'Automatic' or 'Manual'
'Manual' creates a reference type 'Default'
'Automatic' creates a reference type 'Relation Reference'
But I cant find any documentation about these types of relation
We currently use a very crazy method of using family tables to create left and and right hand versions of parts where we create all the variant geometry in the generic and then turn it on and off in the respective instances, it is very robust because instances and generics can be found very easily from within Creo and within Windchill. I would prefer to move to using publish geometry as the family table methods can only have one designer working on the instances at any one time, but I need to understand how objects are linked in Windchill and how they are collected into workspaces and Change tasks through these relationships.
Any help much appreciated.
0 REPLIES 0
