Publishing drawing to pdf
dm-3
If convert a drawing file to pdf the dimensions are getting distoreted.
Help me in resolving this issue.
Dhinesh
3 REPLIES 3
HatimAbdul
(To:dm-3)
Distorted in what way? Is it a font problem? May I suggest using the option in the image attached ("strike all fonts" in the Contents tab). It might help but it may make the resulting file bigger in size.
dm-3
(To:HatimAbdul)
Abdul,
Dimensions are getting distorted in a way that the witness lines are getting moved away from the reference edges.
The offset value applied for the witness lines is getting increased or decreased once I publish drawing to pdf
Dhinesh
MartinHanak
(To:dm-3)
Dhinesh,
try to use PDFCreator to generate PDF.
Martin Hanak
Martin Hanák
