Hi All,
Can the geometry data be extracted from creo simulate result file or result folders generated after analysis?
for example, the surface data , stress at each hard point etc
Any idea would be very helpful.
Thanks in advance.
Srikanth
Hi Srikanth,
You can output a VRML file with the Stress, Strain, and Deflections plots overlaid on the model.
Hope this helps,
Don Anderson
Thanks Don Anderson,
I am not able to understand or interpret the data in the file you have attached. Could you please help me with it.?
Also are these points recorded after dynamic query? or stress on the nodes created..
Srikanth
The file was an export of the results window i had displayed.
