Query regarding assignment of .mfg file to cabling drawing.
nshete
Hello All,
I have created XXX_mfg and XXX_flat from my original XXX.asm file.
When I create a drawing, I have attached the _MFG file with the drawing. But the tables are not getting populated.
Instead, if I attach the _FLAT, all the tables and other data populates fine. Which is as per requirement.
The only problem is, whenever I update anything in my _MFG file, I have to place the fresh view and place all the tables again which is very painful.
Is there any method to avoid this.
Nitin
0 REPLIES 0
