RE: Family table listed in drawing - Addendum
TrainStopper
7-Bedrock
Many thanks to John P for not giving up.
I finally *understand*, I attached a .tbl file for a simple repeat region
(not 2D) that is now working fine for me.
First, in the part the dimensions need to have a name, A, B, C, etc. You can
do this by going into the dimension properties and replacing d# with A, etc.
Add whatever parameters to the family table in the usual way.
The problem was not with the family table, the problem was with setting up a
repeat region to display the family table contents in a drawing.
In the drawing the table parameters need to be:
fam.inst.name (in one column) fam.inst.param.value (for each of the rest
of the columns)
AND for each column, you need to create a filter &fam.inst.param.name == x
Where x = the name as it appears in the part’s family table, no quotes.
Best Regards,
Walt Weiss
0 REPLIES 0
