RE: seed - boundry surface - answer
ptc-294120
1-Newbie
Did you know that if you hold the cursor over the text on the screen
that says 'Seed & Boundary Surfaces' and right click a menu comes up?
Well neither does PTC Tech support.
In that menu is 'activate set' option where you can then go and select
more bounding surfaces.
Thanks to François for the quick answer.
Have a good day,
Dave
0 REPLIES 0
