RSD -vs- Mentor Graph
msexton
Once again I find myself at a company that is fairly new to using Pro/E and brand new to using Pro/Cabling. The next part of their migration to 3D will be using logical references to drive the Pro/Cable model. The decision hasn’t been made yet, to use RSD or Mentor Graph for the schematic and the logical referencing.
I need to put together a listing of the pros and cons for each program for the EE’s and upper management to look at before going forward. Any and all experiences, good or bad, would be a great help.
TIA
Marshall Sexton
Design Solutions
Marshall,
I would be interested in any replies that you get offline. We are looking into Mentor and RSD as well
Mario Santana
Varian Medical Systems.
pabuckh
(To:msexton)
Have you received any feedback regarding this? I am in currently looking at options for our group as well.
Phil
jellis
(To:msexton)
In Reply to Marshall Sexton:
Marshall...I can not speak for Mentor Graphics. Regarding RSD and ProE: that's the combination we use. Ours is mostly OOTB however there are some companies who have configured it with java to suit their processes. As with all software combinations you must consider on-going support. There will be technical issues with either application. Where do you go if theMentorlogical refs don't import to ProEaccurately?Both ProE and RSD are supported by PTC. One must also consider the future of Creo and the potential implications it would present functioning with third party applications. You could get into a situation where you wouldn't be able to upgrade one or the other because of functional incompatibility.
A couple of our Elec and Hyd Engrs have peaked at Creo Schematics 1.0 and they have been pleased sofar. Still much eval to do.
Regards, Jim
TIA
Marshall Sexton
Design Solutions
