Radial Axis centerline.
CBenner
8-Gravel
Is it possible to trim a radial axis pattern centerline ina drawing? ie: A bolt hole pattern centerline? See attached.
<u>
</u>
Chris Benner
Autodesk ® Expert Elite
First, you need to divide the circle into two arcs, then you can trim each arc .
