As per the post, Having the same problem. Datum Feature Symbol appears at the same place on every single sheet of a drawing. Creating a new sheet results in the same problem. Symbol cannot be selected while on any ribbon tab, whether alt is held down or not.
What happens when you create a new drawing with no template or format. Does it show up then? What about a new drawing with just the format?
Thanks! That worked!
Try opening the format to see if it is there.
