Re: Datum Feature Symbol
BB_9593767
2-Explorer
As per the post, Having the same problem.  Datum Feature Symbol appears at the same place on every single sheet of a drawing.  Creating a new sheet results in the same problem.  Symbol cannot be selected while on any ribbon tab, whether alt is held down or not.
sacquarone
(To:Chris3)
Hello @BB_9593767  and @Chris3
Refer to post 782920 for possible guidance
Serge
4 REPLIES 4
Chris3
(To:BB_9593767)
What happens when you create a new drawing with no template or format. Does it show up then? What about a new drawing with just the format?
sacquarone
(To:Chris3)
Serge
Thanks!  That worked!
kdirth
(To:BB_9593767)
Try opening the format to see if it is there.
