Kirk;
Here are some options.
Bruce
First, set the DTL setting model_digits_in_region to yes. This will take care of dimension decimal places. For parameter decimal places, which it sounds like you are dealing with, add brackets with a decimal point and the number of decimal places you want at the end of your filter statement like this: &fam.inst.param.value[.2]
just add [.x] as a suffix to the parameter that drives the table column where x = an integer number representing the number of decimal places
2. Autosizing Columns
