Re: New Creo User
seguraa
2-Explorer
Re: New Creo User
As per this thread - same issue
Hello Tmetcalf,
i'm started Pro-programming in Creo, in that i added all values and even i edited program (made it for single dimension) but i'm facing the issue that once i enter the value it should execute the program and modify the model accordingly but it not happening, once i enter value and press ok button again that pop up will come, if i press two times middle bottom it will come out but model will be regenerating to 1st entered value.
how to solve this issue, i need once i enter the value it should not ask again and again.
thanks
