Re:- "Extending" already routed wire
jkmalagi
1-Newbie
Hi All,
I just started using pro/cabling (2-3 days back!!) and could route few wires using Datum points.
The problem I am facing is that I have terminated the wire at an un-intended place and if I move the point to the required position, the wire sags. My Questions are-
1) How do we 'extend' a wire/cable already routed to a new desired location.
2) how can we add points in an existing cable/wire (routed through a series of points) so as to get a better control over the routing.
3) If I want to "strip" a length of wire to show bare copper metal, What is the best way to do it? I am at a loss to figure out a way to add cut features to wires genereated in Pro/cabling!
4) When I create the dwg, the parts behind the cable are visible. Is there a way to avoid this?
Thanks in advance,
Jaya
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
